How to remove this?
Hey, i'm having trouble removing the engine case/cover on my bike for the first time to check the valves. I took off the seat and fuel tank and removed the spark plug cover, and loosened and removed the two allen key nuts on the cover. So now the engine cover comes loose but I can't get it off completely because there's what looks like part of the frame in the way. The bike is the 08 model and i don't know how to get it out. Are you supposed to remove that part of the frame first (it's held on by 3 bolts)?? I can try and post a pic of what i mean if that helps. Any ideas anyone??
you need to remove the motor mounts that attach to the head.. It can be done with out removing them but requires finess and is a PITA to do.. quicker and simpler to just remove the mounts and even then it can be a PAIN..
