stupid fcr question
There is a rib molded in the rubber boot and a groove machined in the head spigot. When the boot is on all the way you will feel it "snap" or fall into place. I would expect the gap to be zero to about 1mm. There is about a 1/2 mm gap on mine.
kinda what i figured..just cant seem to get it on anymore.i can push on it and it will go in further but when i let go it moves back to the spot its at in the pic
If you remove the boot from the carb and install just the boot on the head without the carb, you can both see and feel when it is on all the way. Check the fit on the inside of the boot. If you are concerned about the fit, do that. It should answer all your questions.
