Leaky Carb
Ok, help me out... I am constantly having issues with my carb leaking out of the overflow. I just took it apart and cleaned it, but to no avail, actually I think it leaks worse. I don't believe that the float is sticking, when I pull the bottom drain off and push up on the float it doesn't seem to be stuck.
Any ideas? Thanks.
- Ben
Set floats lower in the bowl to shut down fuel earlier. This can be done by adjusting the needle set tab. Connect fuel back up and check for over flow. If still overflowing check the needle operation. Hopes this helps.
Adjust the float level. If it still leaks, install a new float needle.
