KX springs
I run the stock KX fork spring...it's 10mm longer, so there's some preload...I really like it. With stock valving it makes for a plush offroad fork for my 190lbs no gear.
Not sure about rear spring...I would think so.
i use the kx spring in the rear. same diameter as the stocker. 06-08 remember that.
i wasnt sure about the fork springs. i knew they were 10mm longer thats why i strayed away from them. soo they'll fit right in?
Yep...Travis from TBT told me about it. Cheap way to a pretty good front end.
What did the springs "set you back" as they say? Nice idea:banana:
Got them free from a bigger friend that was doing his KX for moto. I've seen them on ebay for $40
The stock KX spring has the spring rate I need for my KLX. Worked perfectly on the rear shock.
