KLX300 torque specs
Ill go ahead and say i don't have a shop manual, but plan on getting one. I need the torque specs for a couple things. First, i need the 2 8mm small bolts in the head. Secondly, i need the 12 or so 8mm bolts that are holding on the right side engine cover. Also the 8mm bolts on the oil filter cover, and the coolant fan cap(or whatever the spinny thingy is called.) Thanks, Jordan
According to the klx300 addendum of the 250 service manual the two 6mm bolts are torqued at 9.8 N-m or 87 inch lbs.
The outside cover bolts including the oil filter cover are actually the same.
Do not know what the coolant fan cap is since 300's do not have fans, at least the ones I have seen do not. If you are referring to the radiator cap it is turned until it hits the stops.
