Hydraulic brake light switch question
I was wondering if anyone knew the difference between the single and double bleed hydraulic brake light switches by K&S Technologies. One has one hole and the other has 2 holes. Is the 2 double bleed more sensitive to the brake fluid pressure?
Is the baha designs one just as good? I seen it as cheap as 17 shipped. The K&S is 25 shipped.
Edited by XL100allnightlong
ADDING
The double bleed bolt is for a 2-line setup(street bikes). You want the single bleed version!
Ohhh, Single bleed = single line. Double bleed = double line.
Thanks... I had no clue ? :bonk:
Perc
