pit bike bog
hey so i put a munkini carb on my pit bike and they'res a deadly bog on closed to 1/4 throttle. now i think its running lean cause if i turn the choke on a little it runs normally but then the rest of the throttle id off. do i need to buy a new jet or can i adjust the mixture screw out. if i changed the needle clip would that help thanks. i will post a video on youtube with my go pro on so you can fully see but for now any ideas. also if i turn the idle up its better but it over reving. i have a video of it but i had the idle high so i could drive it but. i would like to fix it so i have the best performce thanks
