Checked Valve Clearance today..
AND they are still well within tolerance.
Both intakes a shy under .16mm
One exhaust a bit tight on .28mm and the other a little loose so with the feeler gauges I have it's sitting on .29mm.
Happy to know I don't need to do anything there for a while, my next purchase will be an 08 cam or a Hotcams stage 2.
Sounds good. My 09 still has the shims that came in it and I check it often.
If you stay off the rev limiter and keep the oil and air filter clean you can get a decent amount of time on the stock valves.
