Need Öhlins Info HO 1093
can anyone help me ,
i need the Stock Valvingstacks of the HO1194 or HO 1094 shock.
at time i ride the HO1093 Shock in my CRF 450, works great but the comp is closed to 5 clicks.
i think the 450 valving works better
Thanks!:bonk:
Hi,
the stock stack is for 50N/mm spring which is for 80kg rider, plus you have to change the shaft jet too. How many clicks you are now on CSC??
If you tell me your weight I"ll try to help you
B.
PM me your mail adress and ill give you the setup sheets from Ohlins for the 1093
including the stacks mine came with and the stacks im using at the moment
there is almost no difference in the fork valving 250vs450 as they come stock atleast not what i have seen . dont know about the shock though
Kim
Thanks!
my weight is 72 kg without gear.
intermediate MX
Spring 50 N/mm,
c5
R12
CSC 18
Only MX on hard, loamy Tracks..
Ok, the stock HO10942 (latest version) will work for you:), I'll send you which shims you have to add-change on the main piston and on the rebound adjustment, as I remember the compression stays as it is. The shaft jet "has to be" changed, If I have the shaft jet I can mail it to you, I have to check in my spare parts box.
Easier would be to PM me your e-mail address..
Thanks!
i will try this Setting.
PM send.
do you think i need also install a top out spring kit on the shock?
can you sell me the parts?
lg wolf:worthy:
