Sprocket problem on my 02 cr 250?
Hey guys I have a problem with my rear sprocket on my cr. I broke the sprocket in half(no idea how), and replaced it about a week ago, today I was looking and the teeth are already really worn. Any ideas what could cause this? Thanks in advance.
Did you change out the chain as well? If the chain was worn and you kept it chances are it ate up the new sprocket quickly. Its always best to change everything. I have never heard or a sprocket snapping in half either.
could be a bent axle, bent hub, bent swingarm, etc.
I'd suspect something is bent as well. Theres something tweaked or not aligned right putting pressure on the sprocket causing the failure. Check & make sure everything aligns & is with in spec. Make sure the chain is adj correctly.
My guess is that you ran the worn out chain or possibly put the sprocket on backwards effecting the allignment of the sprockets. Need pics and more details though.
