Lost my rear brake
I was riding yesterday and totally lost my rear brake. It's full of fluid but has absolutely no tension on the pedal as you push down. What could be the cause of this? I'm on a 09 450 by the way. Pads are about half worn with plenty of time still left on them. What do I need to fix it?????
When is the last time you changed your fluid? Or you might have air in the line. You could try bleeding them. I would recommend changing the fluid and reverse bleeding.
The Kawi part no. is 43020-1094 and includes the M/C piston, seal and return spring.
