DIY "woods" port mods for cr250 ( pics)
Ok guys i have had a few of you ask me what the hell i was talking about with my woods mod to my cylinder, i take no credit for this eric gorr shows a picture of this in his book and i just figured out the rest on my own
heres what you need
a dremel tool AND A CHAIN SAW BLADE STONE YES ! THATS NOT A TYPO and some 400, 800 and 1200 sand paper
use slow speed and work the radiuses there are 2 rules
1) go SLOW with the speed and don't stop moving
2) DO NOT PUSH use a light steady touch
if you compare your cylinder to my photo's you can see what i did to open up the sub intake (boyssen ports)
the next step in to get a sand bit and use the grits i outlined in progression
the best way to smooth them out is to wrap a small piece of sand paper around the mandrel ( bit) and tape the bottom letting the top spin like a helicopter this will nock down all high spots, this is how the big boys do it
last AND MOST IMPORTANT STEP !
spray with carb cleaner compressed air fallowed by simple green, then dunk in soapy water NOW DO THIS AGAIN 4 TIMES !!!
so basically you just opened up the intake ports slightly? did this help improve bottom end then as well?
Wish someone would post how to stuff cases on 02+ for more bottom end
That is supposed to be the magic fix for late model CR125s, so I'm interested. 'Course, I still don't even know what "stuff cases" means....
JayC
JayC
the late models have too much case volume, that's one of the reasons they dont have much bottom end, I've read magazine articles about case stuffing, and people have said they have had it done, but nobody has posted a howto, supposedly it's not hard at all, I've seen how to it to a KTM
but not for honda's yet, gotta know the right spots to hit
Here are some pictures of mine. Hope it helps.
yes i opened up the intake ports and blended them into the transfers,
there are alot more modifications that can be done to these cylinders but this one is basic enough for the average joe to do with out screwing up
another word of advise would be to lay the base gasket on the cylinder when you are cutting the metal, that way if you slip you'll mark up the gasket and not your sealing surface
the reason we are using the chainsaw blade stone is it is not nearly as aggressive as a carbide bur and is easier to control
thanks, i figured there would be a lot more material added than just those spots
more like this
did you notice a drastic change in power by doing this mod?
there was no overall gain HP wise, however it like to chug more and it took all hesitation out of the bottom end, i did notice less wheel spin after i did this as well
the only way i can explain it ( with out you hearing, seeing riding ect) would be it feels cleaner in the tight woods, i ride bar tight single track and race in the J-Day series up here in new england so i helped me for what i do
im not a pro but this will help if you ride woods
ohok thank you, it seems like a good idea but im not sure id benefit from this much becasue i ride mx, and am mostly a top end person
Nice job, I have Eric gorr transfer port mods, Iv really been wanting to match the head and cases with epoxy.. Looks great!
