2002 CR 250 rear shock clickers adjustment question
Hey folks, sorry for the dumb question. I tried some searches and couldnt' find what I need.
My 97 CR 250 has a 2002 CR 250 rear shock. No labels telling me which clicker is for compression and rebound. Can someone tell me which is which and what the stock setting for the high speed compression is? Thanks
Compression is on the top and rebound on the bottom. According to my manual, standard settings are:
High speed compression - 1-3/4 ~ 2-1/4 turns out from full in
Low speed compression - 7 clicks out from full in
Rebound - 8~11 clicks out from full in
Hope that helps. :smirk:
Hope that helps. :banghead:
what page of you manual did you find this on as on my pdf 02 - 03 manual i can not find where is talks about rear shock set up. Thanks!
12-2 at the top.
Does anyone know what 1.11/12-2.5/12 is supposed to mean? Is it 1 and 11/12 as a fraction?
Yes there are no clicks on the high speed adjuster
