05 yz250 suspension fit on a 09???
the 05 has an upper pro taper triple clamp. i use the 05 for a practice bike but the suspension is valved too stiff for me. the 09 stock suspension is good enough for me but would want to put it on the 05. before i send out the 05 set up, will the suspension transfer between the bikes?
i've read other threads that are close to this question, but can't seem to get a clear answer. if i understand correctly, there is a 2mm difference and all you would need to do is keep the axle with the correct bike???
Edited by Miller227
title
Since you have both bikes, switch all the parts...clamps, brakes, etc.
