2008 Crf 70 Gears help???
hi there i have a crf 70 which ran perfectly until i went to change the oil, once id drain'd the oil i took the r/h side engine cover off to clean the mesh to stop metal bits going through the engine, after putting the cover back on the bike now starts and runs, goes into 1st but then seems to jump to 3rd it is also very hard to change gears. does anyone have any suggestions that may help us?
thanks
Did you adjust the clutch correctly after putting the cover back on? There's a shaft with a jam nut coming out of the cover on the right hand side that's used to adjust the clutch. I can't remember if you have to mess with the jam nut to get the cover off or not (it's been six years since I've done it). Even if you didn't play with the jam nut, you still disturbed the setup. I would check your clutch adjustment as the first step.
yeah fiddled about with it but un sure of the correct settings, you wouldnt happen to know the settings would you?
cheers
In case you didn't understand the instructions above completely, let me offer some help.
:lol: Counterclockwise = :smirk: anticlockwise. :bonk:
