Help, no spark
I'm having trouble getting spark in my 86 kx250 and I've changed out 8 different spark plugs, nothing. I had another cdi box I changed out and still nothing. I pulled off the flywheel and stator and cleaned it real good then put it back in and still nothing. I dont know what to look for stator wise so if someone could help me out with that I'd appreciate it. And how would I go about checking the ignition box?
Thanks.
im saying, since you did the basics, you need to break out the meter and check all the wires, and make sure all components are up the factory specs. if not, than you will need to replace what isnt working. check all grounds as well. twist the sparkplug cap off and make sure the high tension lead isn't corroded. my 87 corroded and i had to cut the wire back a quarter inch till there wasnt any green wires left.
you did rule out the killswitch right?
I 2nd this. I've seen so many people spend alot of money over a $20 kill switch.:smirk:
BTW. Ricky Stator is the MAN. I've gotten 3 stators from them and they rock!!!
Yes I unplugged the kill switch, the stator has yellow and black, red and tan/white, and green and tan/white. How much do new stators usually run?
Am I suppose to check the blue wire coming off? And when I checked the black and yellow I got about .5. But the black and yellow grounds so I don't know if I tested that right.
