Damper Center Bolt?
Hey guys, I was changing fork oil seals on my 05' RM250 and when I took the center bolt out I noticed the screw to adjust the rebound has broken. I had a look at some diagrams and found the part (item number 51170-37F80) and cheapest I find is $106 which I consider too pricey for what it is.
Is there any aftermarket option for me or is OEM the only way to go? If not I'll leave this broken for now since I have no leaks or such.
Thanks!
Not positive on the aftermarket source, I dont know of one, but never looked.
$106 is pretty darned cheap for a center bolt.. I would have est $130 without looking, and my two main online parts sources had it higher then that when I did look.
Do you know the size? Can't remember but is it the same size as any other Showa? I think they are 20mm X 1.0 pitch maybe? If so I may have a used one....
doc
doc
I'm not sure about the size, it's from a 05'RM250. :/
