87 xl jug on 88 xr 250
i know the bore is bigger and thejug is shorter but is this to short that the compression and clearance is to much any help on this will be gladly accepted
i just bored out a xr jug on my XL250R. same height on both cylinders. Bore is the only difference.
did you use the the xl or the xr piston iam going to bore to 77 mm with this i think i will look into a kit from xrs only ithink this maybe the cheapest route and maybe a 1st stage hot cam has any one had this set up
