E upgrade?
Is a E type full exhaust better than a stock sm system?
yes...the header is your restrictive point on the s/sm exhaust, the real E header is larger diameter. its not a huge gain. most compare the fmf power bomb header to the E pipe. you can still find E headers for cheap if you are patient and check the TT classifieds and local listings and of course ebay.
yes. It is longer then the sm header so you will have to cut about 3/4 of an inch off the stock muffler. Or did I cut it off the header, I don't remember. You will have to use a thinner gasket to get it to fit. some people use pop cans, I used 16 gauge copper wire wrapped like a coil.
