rear shock swap !?!
Can anyone tell me if a rear shock from an 2005 CRF250 will work on a 2002 CRF450?
Thanks so much for any input.
the shock have different foot but for other is the same.
different valving and spring
Will it bolt up in place? or are the mounts different! I can pick one up valved to my weight, but I want to make shure it will bolt on my CRF450.
Thanks
im not sure.i have 250 crf and 450 but the lenght of shock is different ,i cant tell you if can interchange the rod or lower attack and use the shock,you need another opinion
Send me your 450 shock and I can make it do whatever you want, seriously! I don't see why you would need to swap shocks unless yours is damaged beyond repair. The spring on the 250 is probably a lighter rate, which may work better for your weight... any suspension guy can make this stuff happen pretty easily. Valving can be altered as well if there are any other seriously outstanding issues. I have brought some stuff back from the dead with a few little touches.
do a search on cr shock lengths, i posted up lots of info on different lengths and years.Most interchange.
