shock fluid for wp shock
Hi am going to attempt my first service on the shock of my te300, locally i can only get Maxima 7wt medium shock fluid is that ok for this shock or will it need softer compression or something after that????
In a WP shock it is best to run 2.5, 3 or 3.5 weight oil.
the maxima 7wt will need less damping on all 4 circuits.
better to get the right stuff
3wt Maxima is good stuff.
i read about this somewhere, but the manual suggest 5wt motorex forks and shock, what changes are required by using lighter????
cheers
i may be able to get Motul also, have to check with the local supplier if they keep shock fluid
Motul 2.5 wt would be fine.
Shock oil can stand the much higher temp. a shock will run at.
As long as it is shock oil it will be fine.
In recent KTM manuals the Shock oil recommended by WP is 2.5wt.
