mikuni tm28 vs tm28ss
i have a mikuni tm28ss from a suzuki rm80 i would like to fit on a 1974 bultaco aplina 250. bultaco.com gave me an initial starting point for a tm28
main 220
pilot 30
slide 2,5
needle 5dp39-4 [slot]
needle jet 175 p-8
air jet 1.2
the tm28ss seems to have a fixed air jet, the slide is a 4.0 and the needle jet is a 182 p-2, the needle, pilot and main match. sudco shows a 182 p-8 needle jet so i should be able to match that, but i am not sure the tm28 2.5 slide can replace the 4.0 slide on the tm28ss. can i use the tm28ss 4.0 slide and use a richer needle?
here is what i have learned from sudco.
I am not exactly 100% on the exact difference between the 2 carbs as I am Mikuni Aftermarket and the TM28SS is an OEM carburetor.
I do know the 182 series is primary style needle jet and the 175 is a bleed style. Primary style needle jets run about 4 size richer than the bleed style.
The throttle valve major effect is right about 1/8 throttle if you are having a lean bog right around there then the 4.0 slide is an issue.
the tm28ss came with a 182 p-2 needle jet, so it should = the 175 p-8. any thoughts on the throttle valve cut, like can i go one needle jet richer to feed the leaner slide? the only 2.5 slide i have found is $85 and a new tm28 can be had for $115. also i will be adding a mzb cdi ignition rather than the standard points, condenser set up.
Edited by dr1445
