Quick Gorr 295 Insallation Question.
Do the stock head nuts fit the 295 modded head? The studs look a little long but the nuts are pretty tall. I like to curse about having to run to the store as early as possible.:smirk:
I had to grind the top dome off the nuts in order to tighten them all the way down.
This has never been raised before, is there a difference in stud length?
I have 2 sets of cylinders and heads. I had no problem with them.
Do you have the OEM copper washers on there?
I think those brass, or gold colored washers are for corrosion. The corrosion gets these before it attacks the aluminum.
No problem with the studs on my cylinder.
