Restackor question
Can the software tell me what shims I need to make my suspension softer?
Say I want to soften the front forks low speed compression by 6 clicks can it tell me what shims to use?
Thanks
one face shim is not ever 3 click!!if you have a piston whitt larger flow or whit little port a shim make a different DIFFERENCE
if you have free bleed on base or you havnt a face shim make a different DIFFERENCE
the kind of oil make more difference then one face shim
the software is very good and cheap for me
