do dr 350 wheels fit the z?
I had a 96 dr350s and the bearings are a different size. I have a couple of left overs and tried to use on my 04 DRZ400S and they won't work with the stock axle anyway. You might be able to check around & get the correct bearings to fit the hub and the axle. Not sure about the width issue or if the sprocket will align.
