Ktm 125sx 2005 shimstack for woodriding
hey! I would like to have a good shim stack setup that I can assume for forest driving.
It is a wp fork that sits on a ktm 125sx årsm 05th
I weigh 82 kg less equipment and run with org spring.
I have 115/35 on the rear spring hangers, and 130 of the air gap in the front fork. I drive only enduro and I want to get a smoother ride over roots o stone. the bumps / higher speed works fine suspension right, I think, but as soon as it becomes a bit of rocks,roots he becomes bumpy o struck.
shims stack setup org
Rebound
1* 16 .0,25
2* 8,5. 0,30
1* 14. 0,11
1* 16. 0,11
1* 18. 0,11
1* 20. 0,11
1* 16. 0,11
4* trian
mid
4* 24. 0.11
1* 22. 0,11
1* 20. 0,11
1* 18, 0,11
2* 10,96. 0,44
1* 11. 0,11
comp
10* 24. 0,11
2* 22. 0,11
2* 20. 0,11
1* 18. 0,11
1* 16. 0,11
1* 14. 0,11
1* 12. 0,11
1* 18. 0,11
I have tested the following set-up. it was better but far from good
comp
18x0.25
9x0.30
14x0.10
16x.10
18x0.10
20x0.10
22x0.10
24x0.10*6
12x0.10
24x0.10*2
mid
1 x11. 0,11
2 x10,96. 0,44
18x0,10
20x0.10
24x0.10*4
reb
Trian 24x0.10*4
12x0.10
20x0.10
18x0.10
16x0.10
8.5x0.30*2
16x0.25
I would appreciate if you could help me
thanks
Greetings Fredrik from Sweden
try
Comp.
4x24.1
12.1
24.1
22.1
20.1
18.1
16.1
14.1
9.3
mid
2x24.1
22.1
20.1
18.1
11.4
11.1
reb
3xd24.1
12.1
20.1
18.1
16.1
2x8.5x0.3
16.25
start with 120mm air gap 5wt oil
comp 20
reb 18
Thanks!
what do you think about this stack that I found on another forum?
" This is a quote from Coach...Here is a stack Terry Hay supplied me last year to run in my 125. It worked awesome for me, and I plan on running it in my '05 forks!! "
Comp
1x14x.1
2x24x.1
1x19x.1
1x17x.1
1x15x.1
1x13x.1
1x12x.1
1x11x.1
1x10x.2
Rebound
3x24 delta
1x16x.1
1x24d
1x22x.1
1x20x.1
1x17x.1
1x14x.1
1x12x.1
1x10x.1
Midvalve
3x24x.1
1x19x.1
1x14x.1
2x11x.1
1x24x.25
