Adjustable camshafts
Do you guys know any company that makes adjustable cams for the kx's? Ive found them on tokyo mods for the crf's but i cant seem to find them anywhere for the kx250f. Thanks :smirk:
No, the crf cam is adjustable because the cam sprocket is bolt on so they just sell a sprocket with extra bolt holes. The kx250f cam sprocket is press on, so technically if you want to change your timing you can just press the sprocket off and press it back on at whatever + or - degree you want.
I understand hiw the adjustable cam works i just wasnt sure if they had one designed for the kx to make it easier. With an adjustment you can do it with the cam in the bike but not if i need to press it off everytime. Thanks
