WW FB2600 Water Tank replacement
Greetings Group...
Does anyone know where I can get a replacement tank for a FB2600? I need the one closest the front, 50 gal.
Yes, I have tried to repair it. The crack is in a really tough spot on the corner beneath the upper T-section from which the tank hangs. Really a high stress point. Plastic welding just won't hold up.
I figure WW used a standard dimension tank. I am just having a little trouble locating a source.
Thank you.
Thank for the response.
I did check that site out and several others out and I can't find the correct style.
The FB2600 (and probably all other WW trailers) use a T-shaped tank that hangs on two rails (angle iron).
I hope someone can chime in if they have replaced theirs.
Or maybe know of a place in southern California that repairs them. I gave it my best shot and I have done a bunch of plastic welding. Maybe a pro can pull it off.
Ronco plastics in Tustin. They will either make you a custom tank or I think they still do repairs if you bring it to them. If it were me, I'd replace versus repair. the stuff WW bought was crap.
Warriorlifestyles.com
They are still building a similar trailer. They also did some work on my trailer a couple years ago and I am real happy with their work.
