XR400 oil cooler to XR250R 96+
Hey does anyone know if the stock XR400 oil cooler lines will bolt to the XR250 with the XR400 oil cooler? I have the cooler, but no lines. Need to know if I need to make my own up or if I can just get some stocker XR400 oil cooler lines. 2001 XR250R
Thanks
Hello,
I may be wrong (I just searched schematics quickly) but I believe the frame sump is the oil cooler on an 01 xr250r. Oil coolers are listed up to the mid 90's. My 89 oil cooler is oriented with lines attached to top of cooler. My 96 400 is oriented front & back. The attachment to right side of case for lines looks similar between both maybe there is a way to use the 400 lines???? A heavy equipment hose repair may be able to whip something up (usually not cheap) or you could cobble it with some npt (?) fittings on your own.
There are also some cool oil cooler installs in the xr650/600 section with aftermarket parts. See the following in their forum for ideas.
Rate Topic
xr600 fitting an oil cooler
Started by Karlo, Sep 14 2011 10:36 AM
TT is full of great solutions.
Vertical opposing digits
