Bold Print Technical Data - Carburetor in Manual
Looking at the owner's manual for a 2012 300 XC-W under the Technical Data - Carburetor, does the bold print mean that is your factroy carburetor setting? In my manual the bold print is in the box indicating it is set for 1,001 ft to 2,500 ft above sea level and 61 degrees F to 78 degrees F. If that is the case then I should be about right for TN riding. Settings are:
2 ASO
35 IJ
N2ZK NDL
4 POS
165 MJ
Probably the factory settings but many times the dealer changes something to more suit the local conditions. you need to open 'er up and check.
Joe
