600/650 Brake Caliper?
I have an 85 XR350 with a 600/650 front caliper, so i was told.
How do I tell what year model (600/650) it is.
I need new pads. They only contact 2/3 the surface of the 350 front disc.
I would say your best bet is to take the old pads to a shop that have pads in stock and compare its the only way to be 100% sure.
Or take a pic and someone on here can prob verify
Edited by dubkatz
I'll try to get a picture up, but....
It's a NISSIN brand on the inside face (outside of caliper not behind the pads) is some numbers
3 H 8 with a 2 off to the right
and a 27 directly underneath the H. Only markings I could see.
How can I tell if the caliper is retratcing correctly. It seems to stick based on whell not spinning freely, but may be because the uneven wear that creates a lip on the worn pad leaving the top 1/3 of the pad not worn at all.???
