fork preload ?
If you have 3mm fork preload and went to 10mm preload , what would the forks do or feel like in the bars ? what would less preload be good for and what would more be good for ?
7mm more preload make the fork spring rate +0.1 in the first 7-8cm and same rate to other cm of travel.
that s make the fork up in stroke a little in the first cm.
