2010 COLD Clutch slipping!
I have a 2010 250r and it has aprox 45 hrs on it. Around hour 35 i started to experience clutch slipping issues. The weird thing is, is that it only slips when its cold. Once I ride around the track a lap or so there is no longer a issue. When its hot it grabs fine, when its cold slips like crazy. Anyone else have this problem or know of a solution? Oh and removed the clutch from the bike and all the fiber plates look good, steel plates aren't smoked and also tried replacing the springs and still does it.
at 45 HRs its time to think about replacing your clutch plates or else this can happen. everything looked good 2 except these 2 clutch fibers
this was my brothers '10 crf250 clutch that i replaced for him
same symtons you are facing, not grabbing when cold.. it was hard to pull to (obviously), they may look good but stock clutches get weak easily.
i threw the Hinson replacement clutch in there and let it warm up good and its better than its ever been.
Edited by AJMAG247
Both my 2010 and 11 slipped a little when cold but grapped when it got hot ,i think its normal
at 45 hours i think it must be time for new plates though
Kim
