Header pipe?
Anyone know for sure….. Are the header pipes the same for a 2002 XR200 and the pre e-start CRF150F?
They sure look the same, but before I buy a replacement header pipe for the XR200 I’d like to know.
Cross referencing the OEM Honda part number (18320-KT0-670) for the XR200R pipe HERE shows that the pipe was used on the '86-'02 XR200R models only. There is no reference made to any CRF150F model.
CRF230, and I assume the 150, pipes have the same bends as the XR200 pipe except near the end. My memory says the crush washer at the head is the same for all three.
The differences in the pipes will be at the end where it joins the mid pipe/muffler. When looking for XR200 aftermarket pipes I was told that a pipe for a 230 would fit but would need some modding at the end to locate it for the XR200 mid pipe. Seems easy enough; I modded a Powroll header to fit a RM chassis with a single cut about 4" from the end, clocking the pipe, and rewelding.
