piston ring compressor
what piston ring compressor works best on a four stroke ? the rod is so short the one i have is to wide to get the cylinder on.
Or dont be a child and do it by hand which takes 2 seconds on a 4 stroke with only 1 compression ring.
If your cylinder has clearance notches at the bottom/sides, you can run the piston into the bore on the bench, then set the cylinder on the cases on a pair of wood blocks, then install the wrist pin.
thanks grayracer 513 for the reply. i had that idea a couple of hours after i posted on here and tried it with my old piston and rings to see if it would work.it did. so thanks anyways.
Good to know!! On a single I always used my fingers but it can be a bizzo.....I'll have to try that sometime.
I love this forum. I'm here primarily to learn, and add a kernal or two here and there if I can. :smirk:
