clutch problem,lifter lever
Hey I have a 2000 650r put new clutch in and let clutch out and it hopped out of gear.Took it apart everything fine but the lift lever arm feels loose.Would a worn spring cause this or is this internal,thanks.
When I pull the clutch there is no resistance,the arm on the side of the motor doesnt pull the slack out of the cable.Spring is fine just seems weak
