would you replace this?
This is the water pump gear and shaft from my 01 kx 250. IMG_20120129_175723.jpg I am getting antifreezein my oil so I'm replacing the seals and noticed very lite grooves in the shaft and I'm not sure if I should replace it too. ( its $58 )
if its grooved, replace the shaft and your bearings along with the seals. better to be safe than sorry.
Kinda
what I was thinking but didn't know if it was a big deal
if you put the grooved shaft back in it, it may or may not cause seal failure again. if you want to chance it, don't replace it. i wouldn't chance it :smirk:
I re-used a pump shaft that looked like that once. I blew out the new water pump seal in a couple rides. I would get a new one before replacing the seals.
ANY grooved surface that a seal rides on will leak again eventually, its just a matter of time.
