maxima air filter cleaner
just wondering if anybody uses it and why the directions say to soak filter in soapy water after cleaning it. what if i dont soak it?
They want you to remove all traces of the cleaner from the foam (and then completely dry it) before you apply the filter oil.
If not, there's the risk any cleaner still in the foam will dillute and thin-out the filter oil, making it not work as well as it should.
Maxima FFT filter oil is the best I've tried and I use only that, by the way. :smirk:
Edited by YZEtc
The goal is to remove ALL petrochemicals from the filter by soaking it. You have to do it.
