Ball bearing in right side of engine
Hello all
I have an 2004 kx 85
Ive removed the right side of the engine and clutch to replace the shifter shaft
theres a ball bearing sat at the bottom of the engine where the oil drains out
Is this supposed to be there? if not where could it of come from
Any one Have any ideas?
Thanks
no, the bearing isnt suppose to be there. there are 4 bearings located in the governor. check to see if one is missing. other than that, check all the visible roller bearings to see if they are coming apart and replace them if need be.
thanks for the help :smirk:
seems the ball bearing came out of the governor
is there a way i can remove the govenor and put the ball bearing back in
also i had a read through the guide SAPPERS postede (thanks helped me alot) it does not describe how to take out the governor
anyone know of a guide on how i take it out im unsure how to do it
thanks
