need help with adjusting suspension PLS! ktm 250sxf
recently purchased an 07 ktm 250 sxf used awesome clean bike was trail ridden only so the dude has the suspension real soft. I do alot of harescrambles some mx races and some pit riding. I want to keep the good woods demeanor of the bike but i have a problem going off jumps. The bike just wants to soak it up it doesnt have that "POP" if u will off lips of jumps and the front end drops in the whoops. Where should i start at correcting this???what adjustments with the clickers should i make??
Turn in Comp adjusters on shock and fork firstly.
Anyway, you cant get good woods and good MX setup at the same time.
Edited by Vietze
i kno i wont get a good set up at the same time. But im trying to figure out wat adjustments on the clickers will make the bike do wat im trying to achieve.
first check the sag , then turn in the compression adjusters till it feels firm enough( as suggested previously) , if you run out of clickers you need a revalve
