ttr 125 counterbalancer
Yes Easy job when cases are split. Just leave it out. If you want ultimate light weight bottom end remove the counterbalance drive gear on the crank and replace with a aluminum spacer. Motor has a slight bit more vibration but with massively machined flywheel the motor revs very freely.
