09 Questions
First of all, what is a good aftermarket ignition to go with? Can I use an aftermarket CDI from an 08? I see a ton of them up to 08 then 11-12. I have a lot of upgrades on my bike which is still in the build process.
The carb is getting bored out to a 39 or 40mm, we aren't totally sure yet, how do you come up with a baseline jetting after you do that? Do you think an oversized carb bowl is needed?
How do the Pro Circuit cams compare with Crower, Web cams and Ron Hamps designs? I got a set of Pro Circuit cams for real cheap but I can't find much for details about how people like them and where the power curve is with them.
Thank you all in advance, I am new to Kawi.
Edited by rezac
