pro circuit clutch cover
I think you do, but I think they are worthless. The more you use that check bolt, the bigger chance of stripping it. If you change your oil regular, every 5 hours or so and put the correct amount in you don't need that thing. I never use mine.
Those covers are cool looking but they wear easy from what I have seen locally.
Not saying it, as some use it....but you should not use the oil bolt anyway. One it strips sooo easy. Two I have seen it be off just how the bike is sitting on the stand. Use a RATIO RIGHT and follow the manual requirements and everything will be good.
Not sure if it is too late but I have a Hinson cover for your bike and it has a oil level check bolt. Let me know if you are interested.
