'92 XR250L Charging Problems
I've got a 92 xr250l with 10000 miles on it, I take it out and the battery drains and doesnt recharge when being ridden. I put a brand new battery but the problem was still there. I did some looking around and found out that the regulator/rectifier might be bad. How do I check this? Any suggestions on what's wrong?
You get the manual and an Ohm meter and test the pins for the correct readings,,I'd forget all that and just buy a used one,,It is almost guaranteed to be the issue.,
