1996 TTR250 Top end rebuild Needed
have a ttr 250 and it has about 15000 on the clock and blowing smoke also with an oil leak in the barrel gasket. just wondering if anyone had any tips in what other things would be worth replacing in the top end? i know the barrel gasket needs replacing also rings but what else? cheers
Mic the cylinder. If it measures in spec clean and run a hone through it.
It'll need a piston, wristpin, circlips, timing chain, base and head gaskets.
