prim . gear ratio
is there someone who has change,d the primari gear ratio to bring down the rpm of the clutch . the crf has a grazy high clutch rpm because a low gear ratio . when you make the clutch gear bigger and the crank gear smaller you will decrease the clutch rpm with less wear and longer plate life. i am working on it and i think there is only a + .
