00 yz426f timing
ok, so im still having troubles with my 00 yz426 that i bought non running. i found out that the woodruff key was broke so i got a new one. however she still wont fire.
i have spark, new plugs
fresh gas
carb is cleaned thouroughly
is it possible that my timing is 180 off? is that even possible
No. Because the spark is triggered at the crank, there is a spark on every TDC, so it matters not which one you use to time the cams. In an engine where spark is triggered by a distributor or from another device attached to the camshaft(s), you get one spark every other rotation, which makes it possible to choose the wrong TDC when setting up the ignition. Can't happen to yours.
first off check your spark
if you got spark, put a little amount of gas straight into spark plug hole
if it doesn't start then compression or timing is off check your fly wheel and cam mark to make sure
if it start but doesn't stay running clean carb and check air way to the air filter
i do have spark. but she wont start even with starting fluid sprayed down her throat. i double checked the timing last night and its perfect. any other thoughts?
