00 KX250 Keihin Carb work for conversion?
Just looking to see if a 00 Kx250 Keihin carb will work for a keihin conversion on my bike. One popped up locally, i do know it has a TPS on it and i assume it wouldnt directly plug in. But i did find a sticky somewhere where it describes the wires colors and how to hook em up. If this does work, would you recommend hooking up the TPS and splicing my connector on the keihin, or just leave it unplugged and cap it off?
If it's a crecent slide PWK, I believe they're the same, you can look up the numbers on a parts phish, I used an 04 on mine. I'd also go with the kaw throttle too. I believe motion pro has a throttle and cable kit for the kx, which is much less expense than getting the stock kx stuff. I don't plan on hooking up the tps, the colors of the unit and my cr wires differed from the post, and I tried it out, and am happy, It's much easier and fun to ride now.
