2003 yz250 piston clearance ?
just got cylinder replated. have new oem " d " piston. clearance a snug .004" at top and a slightly snugger .003" at the bottom. is this ideal or just good enough? i tried a search first but no luck. thanks
So I went into the service manual and looked, standard spec for piston clearance is 0.0018-0.0020" with a limit of 0.0040". Should be good, but it sounds like your bore might be a touch on the large side (or you measurments aren't totally acurate?).
Whatever the case, should be good to go!
okaay i had a gray moment, .004 divide by 2 is .002 piston to wall clearance which is perfect. i feel like an idiot thanks to all who tried to help.
