08 silverado stabilitrak problems
This is the second time this has happened to me. It will say service stabilitrak, service traction control, then engine power reduced. I looked it up and its common on 07,08, and 09 models has this happened to anyone else?
It's frustrating second time! Now I'm going to have to get it towed should have been fixed the first time.
Could be a number of sensors from the transmission to the MAF. I had similiar problem that wasn't throwing codes and the dealer finally used a data recorder to sort it out. Ended up being a chafed wire behind the steering column.
Towing company took it to the wrong place was quoted 1100! Then I drove it and ran fine to the other place where I had the previous work done, they said it was a wiring harness from the gas to engine was 400 got half off so it was around 200 maybe that's also why my cruise control wasn't working all the time.
